Results 1 to 2 of 2
    Default QO Plug-on Neutral CAFI Circuit Breakers - Know before you go.
    Some may not recognize. Nor how to decode the triped breaker. It's a brave new world.
    QO Plug-on Neutral CAFI Circuit Breakers - Schneider Electric United States
    Behind the Counter look at: SquareD™ QO™ and Homeline™ Combination Arc Fault Circuit Breakers
    Behind the Counter look at: SquareD? QO? and Homeline? Combination Arc Fault Circuit Breakers - YouTube
    Square D™ brand QO™ and Homeline™ CAFIs are now equipped with TIME SAVER Diagnostics. By simply turning the circuit breaker off, holding down the push-to-test button, and turning the circuit breaker back on, you can quickly identify the type of fault you're looking for.
    How does TIME SAVER Diagnostics work?
    http://download.schneider-electric.c...0700HO1402.pdf
    Behind the Counter look at: Square D™ QO™ Plug-on Neutral Load Centers and CAFI Circuit Breakers
    Behind the Counter look at: Square D? QO? Plug-on Neutral Load Centers and CAFI Circuit Breakers - YouTube
    Behind the Counter look Homeline Load Centers Plug-on Neutral CAFI & Dual Function Circuit Breakers
    Behind the Counter look Homeline Load Centers Plug-on Neutral CAFI & Dual Function Circuit Breakers - YouTube
    Default Re: QO Plug-on Neutral CAFI Circuit Breakers - Know before you go.
    Thanks for the information.
