    Oct 2012
    Burnaby, BC, Canada
    Default Hot water floor heating
    As the picture showing (marked by the green arrows), can anyone give an explanation why some area are warmer and others are not. Thanks.
    Default Re: Hot water floor heating
    1. Distance from supply
    2. Boiler just starting up, water entering the loops will take some time to heat the mass, more so if the tubing is in concrete.
    3. Insulation/radiant barrier improperly installed in concrete.
    Was the heating system running when you inspected or did you activate the system?
    It's only a degree or two different. I would not even worry about it. Like Ray noted, it could be caused many reasons.
    Lansdale, PA
    If the tubing is fed from a common manifold at the end then the flow rate in each tube will vary. Slab temperature can also vary from sunlight or distance from exterior, etc.
    Oct 2012
    Burnaby, BC, Canada
    Thumbs up Re: Hot water floor heating
    Good points. Thanks.
    Yes, it is only 1 or 2 degrees difference, I won't make it a big deal. In the report, I stated " heating source is confirmed". But some clients are asking, we better give them a proper explanation.
    Quote Originally Posted by Gordon Lee View Post
    Yes, it is only 1 or 2 degrees difference, ...
    That's 1 or 2 degrees difference in Celsius ... surely that is hotter than 22 degrees F.
    Mar 2013
    on
    I would guess that the warmer and cooler rectangles correspond to something on the underside of the floor.
    Perhaps a closet for the warmer area?
    FYy'allsI, Canada, including Upper Canada, adopted Metric and joined the rest of the world about 1968, under Pierre Trudeau.
