    Default Dual shower head
    Well as usual you think you've seen it all and then, well you know, ...you've not seen it all.
    Both heads worked, and I guess if you really want to be super clean you use the lower shower.
    Default Re: Dual shower head
    That's one o' dem dar Git R Done multi head shower things.
    Apr 2011
    Centennial, CO
    Did the tub spout function, also?
    That is one redneck body spray...
    Hi
    Yes both shower heads worked as well as the spout.
    Nov 2010
    Safety Harbor, FL
    Hi
    Obviously the lower head is there to clean the lower head!
