Results 1 to 4 of 4
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Default Gas line sediment trap ?
    Jim, Rich, Rick, Barry,
    Did a quick walk-through FHA Final inspection this morning on a property in Little Elm and noted a sediment trap on the furnace & W/H gas lines.
    Do y'all know if there is a Little Elm requirement for them?
    I'm curious as having inspected in Houston for years they are required down there and not similar up here in the DFW market.
    Default Re: Gas line sediment trap ?
    Little Elm is trying to catch up with Highland Park I believe.
    Used to be nothing out there in LE but a bunch of crappy trailers.
    I know that sediment traps are recommended, but I've yet to ever see one.
    Nolan
    You do realize that trap is installed wrong, don't you. Might as well left it off.
    I don't have anything on Little Elm. I write them up no matter what the local AHJ says, since it is in the code and all man. instructions. I do have a little blurb about local practice not using them, but all national standards and manufacturer's instructions call for installation...
    G2419.4 Sediment trap. Where a sediment trap is not incorporated as part of the gas utilization equipment, a sediment trap shall be installed downstream of the equipment shutoff valve as close to the inlet of the equipment as practical.
