    Oct 2007
    Arizona
    Default Flexible gas connector in contact with flame
    On a recent inspection I called out further review for the above title. I searched past posts but could not find specific documentation.
    http://www.inspectionnews.net/home_i...pen-flame.html
    A licensed plumber stated all ok, but I'll be recommending he provide his own documentation. I do not know the brand of piping used, but similar info from Gastite states that the melting point for their tubing is 2400 degrees. I won't be using this as a source obviously, but wondered if any out there could help.
    Thank you,
    Chris
    Oct 2007
    Arizona
    Default Re: Flexible gas connector in contact with flame
    Thanks for the past help. This forum has always been a great help on previous posts. I see that I posted in the wrong area...my bad
    Any other reason for no feedback?
    Peoria Arizona
    If you read some of the different Operating Specifications, the flexible gas connectors are rated from -40 degrees to 150 degrees F.
    http://www.brasscraft.com/PDF/300.02...Connectors.pdf
    http://www.brasscraft.com/PDF/300.06...Connectors.pdf
    Gas Log & Fireplace Connectors
    Jeff
    Aug 2011
    I see similar installations, too. In the past, I called out some and had plumbers, installers and even an AHJ tell me that they are ok. However, if the flex is actually in the flame, that is wrong.....usually.
    May 2010
    No. San Diego Co., CA
    Okay, as long as it is an approved connection for the application and out of direct contact with flame. I haven't run across any manufacturers ( or code for that matter) stipulating any specific distance from flame but obviously the further the better.
    Cool Re: Flexible gas connector in contact with flame
    Flexible gas appliance connectors are not CSST. Flex connectors are approved for use inside fireplaces as long as they don't see flame impingement or significant heat. The unit shown is a sand pan burner. It is a high btu input with a large sloppy flame that could easily waft over to that flex connector which is curved forwards. It should be rotated towards the rear. This is also why gas should enter on the left and wrap around behind the burner so you don't have to shove the burner off center to make room for the connector and valve. That gas line penetration needs to be properly sealed both chinked at the inner wall conduit then with high temperature cement at the knockout.
    Holladay, UT
    Hi Bob, I always learn something from your posts. Gas fireplace installation is not one of my strong points. Where could I go for reference material and installation practices other than the manufacturer. Thanks!!
    http://acloserlookslc.com/
    Loren Sanders Sr.'s Avatar
    Loren Sanders Sr. Guest
    I suggest the piping should all be hard piped with black gas piping and a union used to make the connection. When one makes this type of installation one should ask if one would install it this way in his own home where his family is. Sometimes common sense is in order. I agree with the sealing with Hi Temp Cement is in order. Guys, don't take short cuts in your work...gives you a bad reputation and probably higher insurance rates and possibly a law suit.
    - - - Updated - - -
    - - - Updated - - -
    The very best is Dale Feb's Certified Fireplace and Chimney Inspector's course. It's a week and not cheap but the best there is. You'll learn more about building codes, documentation and and report writing than with any other course I've heard of.
    You can get some good generic information from the National Fireplace Institute at nficertified.org
    HTH
