    Mar 2014
    Wisconsin
    Default Sump pump crock and shelves
    Would like to place a shelf approximately 2 to 3 feet above the sump pump crock. Its a submersible sump pump and the plumbing exits through the wall just below the 2 feet mark. As long as the pump is accessible does code prohibit having anything above the pump?
    Vic Lepouce
    Lansdale, PA
    Default Re: Sump pump crock and shelves
    Nothing that I can think of.
    The mechanical code requires clearance for servicing and access. As long as you maintain those required clearances it will be fine. That clearance would include the removal without taking anything down or apart.
    PROFESSIONAL CONSULTING AND INSPECTION COMPANY INCLUDING FORENSIC INVESTIGATIONS
    http://jeffghooper.com/
    Mar 2014
    Wisconsin
    Quote Originally Posted by JeffGHooper View Post
    Thank you gentlemen!
