Thread: Hot/Cold Mystery
03-31-2015, 02:52 PM #1
Hot/Cold Mystery
Fittings under a bathroom sink. My best guess it has to do with the hot/cold lines entering from a tankless water heater. Your view appreciated.
03-31-2015, 03:30 PM #2
Re: Hot/Cold Mystery
Farthest bathroom from the water heater?
May have been an autocirc (or similar) when there was a standard storage tank type water heater installed. Those are designed to keep hot water at or close to the point of use to save from having to run gallons of water to get hot water to the sink.
Another possibility is that is a tempering valve which keeps the hot water from getting too hot (it mixes cold water with the hot water so the hot water is not scalding hot).
03-31-2015, 04:05 PM #3
Thanks, Jerry.
Yeah, I'm guessing tempering mixing valve. I have one on a shower. Keeps hot water from scalding.
Close match pictures on Granger site.
Best to you.
Don
03-31-2015, 05:01 PM #4
All (2) tempering valves I've seen have Hot in Cold in and Mixed out piping.
04-01-2015, 05:05 AM #5
