    Default Odd find yesterday
    Look what I found yesterday!
    Default Re: Odd find yesterday
    That's one for the books! Good find.
    Oh thanks Jack. Now we gotta pull on them too?
    Jack,
    Sooo ... I'm to presume the water was off to the house ... ?
    Great find!
    Let's see ... cold water side ... must mean cold solder joint ... makes sense.
    No Jerry, the water was on to the house. When I finally got to the crawlspace, I saw that someone had disconnected the cold water line (to the washer) and capped it.
    The hoses were connected to both faucets, so I was going to put one in the drain to test the waste pipes. As I was sorting out the hoses, I noticed the cold side moved a bit more than I see time to time with PEX pipe, so I checked it out.
    I was shocked to say the least!
    Aug 2011
    Funny how a little clue can lead you to a big find.......and a little scary, how easily that could have been missed.
    Great catch.
    Nice find Jack. I know many do not test washing machines but this is a good reason why maybe everybody should to at the very least see if the supply and drain lines are operable.
Tags for this Thread
