Thread: Is this IRMA
    Aug 2010
    BC Canada
    Default Is this IRMA
    This is on a 1990 commercial building. A little touchy but not sure IRMA. Thank you
    Default Re: Is this IRMA
    What is IRMA?
    What is IRMA?
    IRMA is a PRM
    Protected Roof Membrane
    Inverted Roof Membrane Assembly
    These are most often seen on highrise buildings with concrete roof decks, and are typically what is used under walking surface pavers, which are typically installed on pedestals instead of directly on the surface below.
    No, I doubt that is an IRMA roof, it simply looks like a mess to me. More like it may have been some type of spray-on foam roof but does not have the typical top coating a spray-on foam roof has.
    Roofing - American Hydrotech
    KEMPER SYSTEM - Waterproofing Membranes for Plaza / IRMA Roofing
    https://www.google.com/search?q=IRMA...FUr3cZPYA8g%3D
Tags for this Thread
