Results 1 to 11 of 11
    Default The Day of the Bad Traps
    Yesterday's inspections were both interesting, plumbing-wise. I will henceforth call it the Day of the Bad Traps. Two of these were in the same house.
    Welmoed Sisson
    Default Re: The Day of the Bad Traps
    Quote Originally Posted by Welmoed Sisson View Post
    They all look bad but the Flex pipe always gets me no matter when and where i find it...
    I always question why the home centers sell it...
    http://www.jjeffzehnder.com/
    "To trap or not to trap. That is the question." - "Then to suffer the sling and arrows of outrageous rejection."
    "If you can't be with the trap you love love the trap you have."
    I'm amazed at how many S-traps I see in new home construction in the rural areas.
    Aug 2011
    Quote Originally Posted by Jeff Zehnder View Post
    I'll bite........why do you dislike flex?
    I'll bite ... that implies that you find flexible drain tailpieces and pipes 'likable'?
    Aug 2011
    Ok, I'll take the bait.
    "Like" would be far too strong a term for how I feel about flex tail pieces. I don't think there is some default that flex tail pieces are always bad. I have seen them misused as I judge misuse, but when used in gentle turns, I've never seen one being any more problem that rigid pipe in similar use. I've seen them used to create a P-trap which I judge to be a misuse. I've seen multiple flex pieces joined to make an extended connection which I've judged to be improper and likely to cause drainage problems.
    Flexible tailpieces are not approved by the code, therefore there is a default 'not allowed' status for them.
    Aug 2011
    Yes......and in the end that settles it.
    Not self scouring. Therefore prohibited.
    PROFESSIONAL CONSULTING AND INSPECTION COMPANY INCLUDING FORENSIC INVESTIGATIONS
    http://jeffghooper.com/
    Quote Originally Posted by JeffGHooper View Post
    Also has ridges and crevices. Therefore prohibited ... unless may by Lay's, then ridges make Ruffles!
Tags for this Thread
