Thread: Pool Lights
    Tampa, Fl
    Default Pool Lights
    Are pool lights required to be GFCI protected if they are low voltage? I see two types of pool panels which are typically manufactured by intermatic. The first have a transformer for the pool light, but no GFCI reset. The second have a GFCI or "low voltage circuit protector" as they call them on the panel label.
    Default Re: Pool Lights
    All pool lights should be GFCI protected.
    Except (drum roll ) optical fiber ones where the lights are not actually even in the pool, or anywhere close to the pool.
    Quote Originally Posted by Matthew Barnicle View Post
    Then I would not call them "GFCI" protected. "Low voltage circuit protector" has nothing to do with GFCI protection as I take the term, to me, that indicates it is there to protect the equipment and its low voltage circuit.
    If it was "GFCI" protection, it would state "GFCI" or "Ground-fault Circuit Interrupter" on it.
    Richard Rushing's Avatar
    Richard Rushing Guest
    As Rick stated... it needs to be GFCI protected.
    rr
    Greg Bertaux, P.E.'s Avatar
    Greg Bertaux, P.E. Guest
    From an article I published recently, GFCIs are required in the following locations:
    - All bathroom receptacles
    - All kitchen and counter receptacles
    - Garage and unfinished basement receptacles
    EXCEPT ones that are not readily accessible or that
    serve an appliance not readily moved.
    - All exterior receptacles
    - All crawlspace receptacles
    - All boathouse receptacles
    - Receptacles within six feet of a laundry or wet bar sink
    - Whirlpool tub motors
    - Spas and fountains
    - 120 volt swimming pool lights
    However, I agree that GFCIs for 12V lighting around pools ought to be recommended.
    Greg,
    Here is a list I've been publishing since, well, a long time, and update to each new NEC edition.
    Attached Files Attached Files
    While I am at at it:
    William Brady's Avatar
    William Brady Guest
    Jerry thank you for tha page I will keep it on my clipboard.
