    dan orourke's Avatar
    dan orourke Guest
    Default Equipment ground
    Default Re: Equipment ground
    Yes. And the neutrals should be separate from the equipment grounds and not bonded to the panel.
    To add to John's "Yes." ... not only is it 'allowed to be', it is also "required to be" bonded to those enclosures.
