Results 1 to 4 of 4
    Clay White's Avatar
    Clay White Guest
    Default Window Lintel Sagging
    Default Re: Window Lintel Sagging
    Clay,
    When I personally see things as such I just go ahead and recommend that a building contractor be contacted to bid repairs.
    We already know that its sagging or failed, so why bother the expense of calling out a SE just to tell you yes it needs to be repaired.
    JMHO
    Brandon Chew's Avatar
    Brandon Chew Guest
    Veneer is an exterior cladding and not a structural component. I wouldn't call for an engineer unless I suspected the cracking was due to structural movement. If there were no signs of movement I would call for a qualified mason to make the necessary repairs.
    May 2007
    Tyler, TX
    Clay,
    JMHO
    I agree. I've had two houses this year with enough sagging over the garages that I recommended immediate repairs and both times it was taken care of by the seller (albeit grudgingly). Even the agent was glad that I called it out and later told me the mason had told her "it was an accident waiting to kill someone".
    Bruce
