    Jim Dull's Avatar
    Jim Dull Guest
    Default Gas Fireplace Inspection
    I have never inspected a gas fireplace. Friday, I have a home which has 2 of them. I don't know if they are regular or ventless. What do you inspect other than the operation? Do gas fireplaces produce junk that clogs up the chimney? Do they have the same requirements as a wood burning fireplace?
    I plan on taking the FIRE course in the very near future but that doesn't help me much for Friday. Thanks for any input.
    Default Re: Gas Fireplace Inspection
    I think if I were you I'd would just tell your client your not comfortable or have the experience to inspect the fireplace and recommend a fireplace contractor to inspect it for them.
    JMHO
    Rick
    You ca learn a lot just reading through the threads here.
    You can learn a lot just reading through the threads here.
    And don't forget searching the Archive - there's tons of info there.
    Quote Originally Posted by Jim Dull View Post
    I don't know if they are regular or ventless.Thanks for any input.
    Vent less get it's name as implied no vent.
    Might want to read some manufactures install instructions as well.
    Ton of Installation Manuals on this link under technical, Installation Manuals.
    Martin Hearth & Heating
