Results 1 to 3 of 3
    Jim Santos's Avatar
    Jim Santos Guest
    Default Condensation is accumulating inside my HVAC making it leak
    I cleaned drain pan and poured some bleach to clean drainage hose in my unit.
    It's about 4 years old and poorly maintained but cools great.
    I noticed on one of the two front panels to access inside of unit a screw was missing.
    Even though no one had touched unit but me.
    I had been having issues with high humidity in on of my rooms but I live in Florida and I guess that's normal.
    Since I went in there now the inside insulation is water soaked,so much it is dripping from unit.
    I called an HVAC repair service and they are coming today.
    But I want to know if I made this situation happen by opening the unit up and cleaning drain and pipe myself, or is it a normal malfunction that comes with age?
    Default Re: Condensation is accumulating inside my HVAC making it leak
    Quote Originally Posted by Jim Santos View Post
    You likely broke some sludge loose that then blocked the drain. Blow out the drain lines or use a shop vac to clean them. There should not be any water inside the electrical compartment.
    Holladay, UT
    Jim, What did the HVAC Tech find???
    http://acloserlookslc.com/
Tags for this Thread
