Results 1 to 2 of 2
    Apr 2007
    WESTMINSTER CO
    Default ICE SCULPTURE BELOW RADON MITIGATION FAN
    GUYS---had this ice sculpture beneath radon mitigation fan and wrote it up that most likely the rubber connectors are leaking and need repair--sellers radon installer says that is typical and needs no repair--i'm in colorado and i have seen thousands of systems and this is only the second i have seen with attached ice to fan-first was repaired by installer--my radon guy says BS -get it fixed.there radon guy wants me to call him--looking for further assurance that it needs repair--by the way i kicked over ice form in picture--it was attached to fan and all the way to ground--thanks--cvf
    Garland, TX
    Default Re: ICE SCULPTURE BELOW RADON MITIGATION FAN
    Charlie
    not seen in my area but this may be useful info, if you already don't have
    Radon Mitigation Systems Temporary Clogging Due to Ice Jams
    i'd think gas leak soap bubbles would confirm/exclude the need for maintenance
    hth
Tags for this Thread
