    Mike Huppi's Avatar
    Mike Huppi Guest
    Talking Some of these things amaze me
    Look at this one I found today for the RV pad, it might work for cusin eddie
    dick whitfield's Avatar
    dick whitfield Guest
    Default Re: Some of these things amaze me
    I bet they had a hard time getting the wires through the plumbing fittings...
    Ben Gardner's Avatar
    Ben Gardner Guest
    Not too hard if you run the wire through all the fittings and pipe before you glue it.
    Quote Originally Posted by dick whitfield View Post
    Quote Originally Posted by Ben Gardner View Post
    Ben,
    Which is, of course, not allowed ...
    Of course, being "allowed" does not matter when one is: 1) using plumbing pipe (not "allowed" either); 2) running up into the meter (not "allowed" either); 3) ... I doubt they know or even care was is "allowed" ...
    Chico,Ca
    A simple question may be: "What is right about this installation?" The list of what is wrong is a whole lot longer, and the only thing right is the use of a proper power outlet / enclosure.
    Did you turn the valve on to make sure water came out?
