    Terre G's Avatar
    Terre G Guest
    Smile AAV problems (and solutions)
    Since AAV's have been in the discussion recently, maybe these pictures will help.
    Three are of an existing problem, and two are solutions found in "Code Check".
    Default Re: AAV problems (and solutions)
    Figure 6 shows the 4" height measurement taken at the wrong place.
    The installation shown in the photos is incorrect.
    Frank Kunselman's Avatar
    Frank Kunselman Guest
    Not only is the 'problem' AAV incorrect, that's a great example of an 'S' trap.
    The easiest solution is to cut the trap loose and run the drain over to the AAV line to become the drain and vent and replace the current drain/vent tee with an elbow, thus correcting both problems.
    Quote Originally Posted by Frank Kunselman View Post
    Frank,
    I think that's what Terre was referring to when he said "Three are of an existing problem,"
    Eric Smith's Avatar
    Eric Smith Guest
    Would no one else consider the install in the 3pvc pics to be dangerously close to an S-Trap?
    True, but you never know what someone might miss at a glance...of course Terre primarily directed attention to the AAVs.
    Catch you on the next round.
    Cheers.
