    brianmiller's Avatar
    brianmiller Guest
    Default Metal roof, vent flashing
    1st photo: Is this the proper way o installed the vent under the panel? Seems like water will go under the panels to me
    2nd photo: the roofer used caulk in between the panel joints, seems like there shouldn't be a need for caulk? What do you all think?
    3rd photo:The boot of the plumbing vent is cockeyed , a problem?
    Thanks for your help
    Bria
    brianmiller Guest
    Default Re: Metal roof, vent flashing
    Anyone? Help! Please!
    Plumbing stack is correct, however the roof vent is not properly installed and prone to leakage, if not already.
    Jun 2012
    Timmins
    What Raymond said
    Quote Originally Posted by Gilbert View Post
    What Raymond said
    Plus #2 That seam needs caulk. A seam with a generous overlap might not need caulk.
Tags for this Thread
