04-12-2016, 04:47 PM #1
Washer draining into a sanitary T, no trap. OK?
I came upon this clothes washer with the drain line going into a sanitary tea. The pipe disappears into the concrete floor, no visible trap. OK?
04-13-2016, 02:23 PM #2
Re: Washer draining into a sanitary T, no trap. OK?
NO
- open Tee most likely letting sewer gas into the home
- spillage and water damage concerns, hose doesn't look secured / attached
- is the pipe going up a dedicated wet vent, sink drain, what's coming down
- what is the long sweep draining, could pose another problem
04-13-2016, 06:24 PM #3
Recommend a new stand pipe with a trap, problem solved for about $20 and a half an hour labor.
