Results 1 to 17 of 17
    dan orourke's Avatar
    dan orourke Guest
    Lee Nettnin's Avatar
    Lee Nettnin Guest
    Default Re: what do you call
    I call it part of the fascia
    Quote Originally Posted by dan orourke View Post
    the triangular section under the rake board end?
    Box cornice
    Framers in this area call it a "bird box", but box cornice sounds better on a report, unless I guess, your client is a framer from this area
    Clarksville Home Inspection
    JW Goad
    Colorado Springs, CO
    "bird box" is the term I learned when I was building houses in GA. That may be a regional term.
    Bruce Breedlove
    www.avaloninspection.com
    Kevin Barre's Avatar
    Kevin Barre Guest
    It's "bird box" here also...but I learned that from framers...
    I think "boxed end of soffitt" or "enclosed soffitt end" would work for most folks.
    It is also called a "Corner return".
    This website might help with some terms.
    Building Construction & Finishing
    Most of this information comes from a book called "Modern Carpentry" by Willis H. Wagner & Howard Bud Smith, 2003. ISBN # 1-59070-202-6 Publisher is The Goodheart=Wilcox Company.
    It is a book that I use all of the time when it comes to questions about light construction.
    Lloyd Woods's Avatar
    Lloyd Woods Guest
    I call it part of the gable trim
    Brian Hoagland's Avatar
    Brian Hoagland Guest
    Quote Originally Posted by Lee Nettnin View Post
    I'm with you, I think every body else is correct with regarding the framing underneath as to the actual construction terms but the exterior facing is a part of the fascia. Besides, most laymen can get a grip on fascia but lose the ability to understand these other terms. Now if you need to refer to the structural wood elements behind the one by, it might be a good idea to go with some of those terms as applicable in your area.
    Rake return.
    In layman terms, its the end corner of the roof.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    To get fancy: ... Northwest or Southeast ... end corner of the roof
    Richard Rushing's Avatar
    Richard Rushing Guest
    Cornice return.
    Rich
    Apr 2007
    state of jefferson
    we old timers call that a "pork chop".
    Ed Voytovich's Avatar
    Ed Voytovich Guest
    On older houses where the return is three dimensional, and where real carpentry was required, we refer to this detail formally in Central New York as a gable end return. Informally, it's a pigeon walk.
    For this miserable, etiolated, two dimensional detail in modern construction, the term "pork chop" seems just right.
    Talking Re: what do you call
    I start writing pork chop and people will really wonder what I used to do.
    Or what you eat...
