    Oct 2012
    Shelby NC
    Default Ridge vent in a mobile home
    Please tell me ow the ridge vent is suppose to work in this double wide. Where the two sections of roof come together, there is no way for air to get out the ridge vent.
    Apr 2013
    High Springs, Florida
    Default Re: Ridge vent in a mobile home
    It will not!
    www.1stproinspection.com
    Certified Master Inspector
    Like Us On Facebook
    Sep 2014
    New Jersey
    Obviously the sheathing needs to be cut back, just like on any other roof. Do you have an exterior photo?
    Peak Inspection Services | Over 34 Years of Contractor Experience!
    Residential Inspections | Commercial Inspections
    Office: 908-750-6789 | www.peakinspectionservices.com
    Quote Originally Posted by Steve Payson View Post
    Cutting back the sheathing may not be permitted on the roof of a manufactured home - one would need to check with the manufacturer to find out.
    If not permitted, maybe they would permit 2x4 blocking spaced 1 inch off the ridge for the roof sheathing to be nailed to (but that would put the space 1-1/2" to 2-1/2" off the ridge.
    Oct 2012
    Shelby NC
    Yes, it just shows a ridge vent.
    Lansdale, PA
    It is possible that the manufacture called for spaced blocking between the two ridge member and the installer do do follow the plans. Since the sheathing was glued the the ridge members I doubt that the manufacture would call for cutting back the sheathing (which would have to be a wide cut).
    Is it possible that there is some other form of venting (gabled end or soffit). I'm not that familiar with the HUD code. It may have permitted soffit venting only.
    With some manufactured homes the marriage wall at the roof is covered with what looks like a ridge vent. This is kind of new design and from my understanding they are doing it to stop the common leaking problems along the marriage wall. I'm betting that is what you found..
