Thread: pipe fitting
    Jim Zborowski's Avatar
    Jim Zborowski Guest
    Default pipe fitting
    ok, just trying out the picture download here. Anyone ever see one of these, never saw a fitting specifically to jog arround another pipe.
    Default Re: pipe fitting
    Jim,
    Never seen one of those myself before.
    You sure you didn't photoshop that one?
    rick
    Jim,
    There's some severe Rust on the Tee and vertical pipe sections behind that Goose Neck.
    The one in the fore ground looks painted ( to hide rust?) hidden rust scales? It's getting them bumps from somewhere.
    There is one proud patent holder behind that one. Somewhere in poland!
    Ridgewood, NJ
    Seen loads of 'em in houses with galvanized water pipes. Always used to jog around the other pipe.
    Michael Larson's Avatar
    Michael Larson Guest
    They are still available HERE
    South-West Michigan
    Post Re: pipe fitting
    Those and many others. It is surprising to see what efforts were made to make mechanical installations neat and clean in the past. Another lost behavioral trait. The metal support on the CPVC line in the background is a NO-NO.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Quote Originally Posted by Randy Aldering View Post
    Why?
    Metal straps are used, and approved for use, on CPVC fire sprinkler piping.
    South-West Michigan
    Think about that for a minute: how often are sprinkler pipes used? How often are CPVC sprinkler pipes going to be used?
    All piping, regardless of the material, expands and contracts during use, due to both temperature and pressure changes. This expansion and contraction produces movement of the pipe. With plastic pipe, this movement is more pronounced. So, when plastic pipe moves back and forth, like a saw, on a metal pipe hanger, what do you suppose is going to happen, eventually?
    www.housesmithe.com
    "The metal support on the CPVC line in the background is a NO-NO."
    "Think about that for a minute:" where is your supporting documentation to the "NO-NO" part?
    Code?
    Manufacturer's installation instructions?
    What / where?
    Isn't the bracket in question for use with electrical conduit?
    I've never seen one of those in the plumbing isle at the hardware store....
