    Default concrete fan housing support
    Should I have called for a HVAC contractor or a mason?
    Default Re: concrete fan housing support
    I'd call aplumber. Didn't you see the toilet seat jammed under the other side!
    I was thinking 'concrete finisher' as that is kinda rough ...
    Richard Rushing's Avatar
    Richard Rushing Guest
    From the looks of the unit and that rock... you need an archaeologist.
    rr
    Looks like the floor threw up.
    Joseph P. Hagarty's Avatar
    Joseph P. Hagarty Guest
    The Air Handler most likely was experiencing High Vibration due to the Corroded base of the unit.
    Packing cement under the Blower curbs the vibration.
    Typical professional HVAC repair in Philadelphia.
    What, Youse guys never seen dis before?
