    Apr 2008
    McKinney Texas
    Default Re: Water heater PEX CPCV connection.
    Yes it does.
    Question: Where is that going to/coming from? It goes up to what looks like a male hose thread adapter which has an elbow connector screwed onto it with a black pipe connected to it?
    There are also combustible material being too close to the B-vent/draft hood too - that foam insulation is combustible and needs to be 6 inches from that draft hood.
    Apr 2008
    McKinney Texas
    Yes it does.
    It is a thermal expansion valve (made by WATTS).
    Yes, I was aware of the combustion material (insulation).
    I do not believe CPCV will bond with PEX in a pressure line. What do you think?
    What is the approved discharge drain line material for it?
    Nope - all materials are required to be assembled and connected with proper materials and fittings, which means there needs to be a proper fitting/adapter between the CPVC and the PEX.
    Section P2906 Materials, Joints and Connections
    (the see the following sections - too much to type)
    - P2906.9 Plastic pipe joints
    - P2906.9.1 Solvent cementing
    - P2906.9.1.2 CPVC plastic pipe
    - P2906.9.1.5 Cross-linked polyethylene plastic (PEX) and its two subsections Flared joints and Mechanical joints
    Lansdale, PA
    I am looking at this on my phone and cannot see it that well. ls that coming from the TPR valve? Regardless, it looks like a DIY mess.
    MONTREAL QUEBEC-CANADA
    Solvent-based glue will soften the PEX tubing and the joint will not hold.
    Holladay, UT
    There's no reason they couldn't have continued that small black line all the way to the floor drain. Was there a floor drain? Here is the spec sheet for the BRV. By the way, I see these leaking a lot. They are designed to relieve pressure from thermal expansion but if you see it running constantly it is broken. I include this in my reports so the clients can monitor it.
    http://media.wattswater.com/es-BRV.pdf
    http://acloserlookslc.com/
Tags for this Thread
