		Thread: Hot tub Panel
	04-12-2007, 11:22 AM #1 Hot tub Panel Hot tub PanelLast edited by Jeff Eastman; 12-19-2007 at 03:16 PM.
	04-12-2007, 02:33 PM #2 Re: Hot tub Panel Re: Hot tub Panel*IF* that ground lug is attached at the proper location in that enclosure, and it looks like it is not. There looks to be a raised dome with a flat top, most likely with a screw hole in the center of it, just to the right of the neutral terminal bar, this is where the ground terminal 'should be' (if I am seeing correctly) attached.
 If that were the case, and *if* that ground terminal was rated for 2 equipment ground conductors, then okay - but - not all of those smaller single terminals are rated for 2 equipment ground conductors.
 It would be better and safer to have just installed a multiple terminal lug in the correct location. That would also eliminate any questions raised by this installation.
	04-12-2007, 05:39 PM #3 Re: Hot tub Panel Re: Hot tub PanelWell they did say they wanted a "HOT" tub.
