    Scott Lynch's Avatar
    Scott Lynch Guest
    Default Wiring in A/C disconnect box
    Default Re: Wiring in A/C disconnect box
    Scott
    The 14 gauge wire is not connected to this HVAC disconnect box and should be enclosed in it's own box.
    That's the low voltage wiring ... see it coming out of the fitting with the power conductors?
    *NOT ALLOWED* in the same raceway or enclosure as the power conductors.
    By the way, you also wrote up the white wire with the red tape, right?
