Thread: Skylights
    Warren Alderman's Avatar
    Warren Alderman Guest
    Default Skylights
    Default Re: Skylights
    No.
    BUT ...
    Having the curb 4" high would be a good reference point, the manufacturer's installation instructions would state 'how high' the curb should be for their skylight installation to meet their listing and labeling.
    Having the corners soldered or welded would be included inn however the manufacturer have their skylights during the testing for their listing and labeling.
    Richard Stanley's Avatar
    Richard Stanley Guest
    The important thing is "How did you do that second picture"?
    Fuquay Varina, NC
    Lightbulb Re: Skylights
    The curb(framing) is 6" on flatter roofs and 4" on steep roofs. They use 2x4 and 2x6. The flashings are field bent by the roofers and if installed correctly doesn't require welded seams or caulking except up under the top where the pan is. Done hundreds of these.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Warren, Yes, the split screen.
    Tim Moreira's Avatar
    Tim Moreira Guest
    I think someone else just did that on another post.
    Please share for show and tell with the rest of the class how you do the split screen pics.
    Tim,
    Open up any graphics program, open the two photos you want to use, check their sizes, then just create a new (blank) image in the graphics program with the same height and twice the width of the photo being inserted, then copy one photo and paste it into the new image, then copy the other photo and paste it into the new image next to the first photo, viola ... two images in one!
    Tim Moreira Guest
    Cool
    Fuquay Varina, NC
    If you don't try these http://www.openoffice.org/index.html same stuff as MS but for free.
    Tim Moreira Guest
    Thank you all for the help.
