Thread: Glazing bead
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Glazing bead
    Default Re: Glazing bead
    The glazing bead is to hold the window pane in place
    Not those vinyl or aluminum ones, they are just decorative. The glazing is held in place by the sealant.
    That plastic trim in your picture looks like its been beat to hell with hail.
    Those chipped areas as is present on the side is a giveaway. Always a clue to check out the roof really well.
    As JP said, there should be sealant around the glass panel which would keep the moisture out.
    Looks like the window has a lost thermal seal anyway, so it needs to be replaced.
