    New Mexico
    Default Manual J Calculation
    I know the term Manual J calc comes up a lot, especially when sizing AC units. Have any of you physically done one? And if so, what program did you use if it was on a computer? I'm having trouble finding one that will allow for more than basic insulation levels. I see that the WrightSoft program comes in at about $300, which is not a big deal if you design systems, but pricey for a one off design of my house. I know I can probably get it done at the plumbing supply house, but I'd like to do one on my own first to cross check their numbers to determine my boiler size.
    Kind of funny how much it is focused on AC size, since we won't have any cooling in the house.
    Bill Chinook's Avatar
    Bill Chinook Guest
    Default Re: Manual J Calculation
    If you are not cooling the house (which is a mistake in my opinion, to not installing cooling), you should not need to do a manual j. There are base guidelines for how many btu's per floor the house will require with insulation values.
    With the world of variable speed furnaces, you can overestimate slightly and not have any negative affects with "heating too quickly".
    If you are using a boiler system, there should be methods of restricting the amount of hot water sent to each room as well.
    Marshall Brown's Avatar
    Marshall Brown Guest
