Thread: Introduction
    Oct 2016
    Illinois
    Default Introduction
    Question for radon testers...which program do you use to generate the drawing
    Capistrano Beach, CA
    Default
    Hi steve kostro and welcome to InspectionNews!
    I'm Brian Hannigan and I created InspectionNews.
    I hope you find everything you are looking for on this site.
    If I can help you in any way just let me know.
    As a "Thank You" for making your first post I have a gift for you. You can pick it up at:
    http://www.SendYourFreeCard.com
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Introduction
    Welcome to the forum, Steve.
    Each state has its own requirements for radon testers, including those which have none.
    The "drawing" to which you refer is probably only required in Illinois and a few other states with similar requirements. Please note that your question will likely only be answered by those who need to submit such drawings. Mine does not.
    That being said, and not knowing fully your requirements, I can add my 2 cents regarding quick layout drawings. I have made these as needed for construction proposals.
    I had used TurboCad 2D in the past. I think it is no longer available. It was representative of a simple CAD program in that, once you learn the method of laying out a room, you get faster over time. There are many open source programs which would offer you the same level of quality. No particular products come to mind in particular, however.
    I had also used Google SketchUp on occasion. This is easily obtainable, and can be adaptable for basic line drawings.
    GRANT MEDICH
    1st Call Home Inspection, LLC
    Rockford, Michigan
Tags for this Thread
