    Al Roden's Avatar
    Al Roden Guest
    Default @ 2" ceiling plate?
    Anyone know what this thing on the breakfast area ceiling is - it's about two inches in diameter and is in a few other rooms too.
    Default Re: @ 2" ceiling plate?
    Glass breakage detector for central alarm system.
    Al Roden's Avatar
    Al Roden Guest
    Thanks Raymond!
    Curtis Kind's Avatar
    Curtis Kind Guest
    Many newer homes have fire sprinkler heads covered by plastic caps. They pop off when the system activates.
    - - - Updated - - -
    May 2015
    WA
    Lightbulb Re: @ 2" ceiling plate?
    Yes sir! You find those in most multi-family units! And some homes.
    - - - Updated - - -
    I've seen something like that without the holes in it. One in the kitchen, one in the living room. They were the capped off lift point for a manufactured building. Look on the outside roof above the cap to find out for sure. There will be a raised nipple where the cable passed through. It should be capped off; if it's not... it will leak. (I'm aware another forum member identified it as a glass breakage sensor... it probably is... just putting in my two cents worth).
    - - - Updated - - -
Tags for this Thread
