    Default White powder on insulation in attic
    Can anyone explain this white powder on the insulation?
    It is very light and spread throughout the atticDSCN0518.jpgDSCN0519.jpgDSCN0511.jpg
    Default Re: White powder on insulation in attic
    Borax ?
    Osceola, AR
    Yep, quite possibly boric acid, a ton of folks use this as a pesticide.
    Yet another reason to wear a good quality respirator when entering attics.
    Alton Darty
    ATN Services, LLC
    www.arinspections.com
    Thanks for the feedback
    Borax and icing sugar is ant poison.
    Check for Carpenter ant nests, piles of sawdust and debris. In the piles, check for dead ant body parts to confirm.
    Another idea.
    Naphthalene or it's substitute (mothballs,flakes) that had been used as a fumigant or repellent.
    MONTREAL QUEBEC-CANADA
    What part of the country you in Bob?
    1: The insulation is a single batt. <4" = ><R12.
    Poor R for any part of the country if the home is conditioned.
    2: An even pattern of staining on the exposed batts.
    3: Stains on the ceiling joists.
    Suspect water intrusion at one point in time.
    White powder, likely borax.
Tags for this Thread
