    Warren Alderman's Avatar
    Warren Alderman Guest
    Default Re: 1976 Slyvania panel
    Probably no different than Zinsco, which Sylvania bought.
    Default Re: 1976 Sylvania panel
    That is a Sylvania / Zinsco panel. How was it taking that panel cover off!
    They are crap.
    Breakers can fail to trip. Breakers weld themselves to the bus bars. Breakers have a tendency to slide down the bus bars and at times will slide all the way off and just dangle in the daylight! I no longer take the covers off of this panel. I have boilerplate that tells everyone about this panel and the issues it has.
    Joseph P. Hagarty's Avatar
    Joseph P. Hagarty Guest
    Same here. Replacement would be recommended.
