Results 1 to 1 of 1
Thread: Transfer switch
04-21-2017, 07:11 PM #1
Transfer switch
The transfer switch is fine. You can't turn on the generator circuit without turning off the utilities circuit. It insures there is no feed back to the utility. The problem is the breaker is limited to 30 amps. You have to turn off unwanted loads. If the AC cycles on the breaker trips. As long as the home owner knows what they are doing there is no problem.
