Thread: Lighting in Attic
12-17-2007, 04:44 PM #1
Lighting in Attic
Similar Threads:Last edited by Jeff Eastman; 12-19-2007 at 03:03 PM.
12-17-2007, 05:29 PM #2
Re: Lighting in Attic
2006 IRC - M1305.1.3.1 Electrical requirements: A luminaire controlled by a switch located at the required passageway opening and a receptacle outlet shall be installed at or near the appliance location in accordance with Chapter 38.
Jerry McCarthy
12-17-2007, 05:50 PM #3
Lighting outlet so one can see Jeff.
It's a write up, trust me.
Jerry McCarthy
12-17-2007, 06:07 PM #4
The light fixture is required at the passageway opening (attic access).
The outlet is intended for plugging tools in for service/repair/replacement, and, yes, they could also plug in a light.as the outlet can be used for a cord/plug light fixture....
Remember, the water heater must be within 20 feet of the access, so a minimum level of light should still be present anyway.
I would say yes because the receptacle for the condenser unit outside must be within 25 feet (a typical extension cord length), so, within 8 feet should work and be okay. The code "at or near", and 8 feet fits the "or near".Would the outlet for the furnace suffice for the water heater when the furnace is located about 8 feet away from the water heater?
