    Dec 2014
    NC
    Default Are condensation pan and safety switch required by code in basement garage closet?
    The contractor recommended to replace the condensation pan and safety switch which is not covered by home warranty in addition to condensation drain line repair. They are saying if they repair, they have to repair up to code. However, I do not recall there is code requirement if the air handler is placed in basement garage closet. Any comments?
    Apr 2013
    High Springs, Florida
    Default Re: Are condensation pan and safety switch required by code in basement garage closet
    Let them do it. It will save you in the future.
    Quote Originally Posted by Mike Tao View Post
    www.1stproinspection.com
    Certified Master Inspector
    Like Us On Facebook
    MONTREAL QUEBEC-CANADA
    Start with M 314.2.1 IRC.
    As for warranty. Refer to your jurisdiction.
    By the sounds of it, you have made recommendations, to which the contractor therein releases your liability. Have him/her put it in writing.
    Such a typical issue. 'The contractor recommended'
    Not a problem thats fine.
    However, what you should be asking is WHY?
    Is the pan rusted out with holes, too shallow, sloped bad, what? If the pan isn't rusted out why should you spend money to replace it?
    Safety switches go bad, no big deal, not expensive, easy enough to do.
    Replace the entire drain line, why? is it undersized, is it clogged and can't be cleaned out, is it sloped wrong?
    Often contractor 'recommendations' on things like this are an 'up sell' to make a site visit more profitable or to fit with revenue projections.
    If a contractor cannot give relevant answer to WHY, then its likely just an up sell
