    Sep 2017
    austin, texas
    Default Drain line configuration
    Is this drain line configuration proper? Looks like it could get sluggish draining out.
    Thanks,
    b
    Aug 2011
    Default Re: Drain line configuration
    Not sure that nut on the top of the tail piece to the sink is threaded properly, but in general, it looks acceptable. Fun to see what folks do.
    Plumbing is not my strongest area, but if that is a double kitchen sink, then I believe it is considered to be a single fixture and should only have a single, common trap.
    Can't remember for sure, the wording could be that a double sink MAY share a common trap rather than SHALL share a common trap.
    MONTREAL QUEBEC-CANADA
    Ingenuity is the mother of invention.
    No adverse conditions observed.
    Recommend: A water slide engineer refer to the homeowner for new designs.
    May 2007
    Marietta, GA
    First huge laugh of the day. Thank you Robert! I nearly spewed coffee out of my nose.
    Every fixture requires a trap, two- and three- compartment sinks are permitted to be considered as a single fixture ... "may" would be correct.
    Robert, that was indeed funny.
    Gentlemen, I am here to serve you as best as I can.
    Happy I made your day.
