    Dec 2010
    michigan
    Default Safety Consultant
    Are there any codes or standards that require the mechanical/utility room in an apartment building to be locked so that individual tenants do not adjust the hot water heater temperature upwards to cause potential scalding to other tenants?
    Capistrano Beach, CA
    Default
    Hello Steven Ziemba,
    I'm Brian Hannigan and I am the creator of InspectionNews
    Welcome aboard. Enjoy your visit here at InspectionNews and if there is anything I can help you with just let me know.
    InspectionNews has many Member Benefits available to you. Some save you time, others save you money and some do both!
    Make sure you view the list of Member Benefits at: http://www.InspectionNews.net/home_i...MemberBenefits
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: Safety Consultant
    Quote Originally Posted by Steven Ziemba View Post
    None that I can think of, and that would not be feasible anyway unless there was maintenance staff on site at all times.
    If maintenance staff was on site at all times, then the mechanical rooms could be locked and there would be personnel there to access those rooms should a need arise, and "at all times" means that more than one maintenance person would need to be on site, otherwise, a single maintenance person would not be able to leave the site; it also means 24 hours a door, so that would be at least two maintenance people each shift (minimum of one maintenance person each shift if the maintenance person never left the premises, and most/many do, for lunch, to get supplies, etc.
    Think of it as a gated community with guards at the gate - 24 hours a day, every day ... that's a lot of man-hours to pay for.
