    May 2009
    New Jersey
    Default Wiring hanging from joists
    2006 build. I thought you needed a 1X6 to attach wiring to floor joists in this manner. Never seen this type wiring in 20 years of inspecting.
    Mar 2009
    Colorado Front Range
    Default Re: Wiring hanging from joists
    As is, the installation doesn't pass muster. If, however, a ceiling is installed, the cables fastened to the bottom of the joists might be OK. The exact code wording says that the joists have to be drilled or running boards used in an unfinished basement, and exactly what constitutes a finished basement is open to interpretation.
    The CSST bond connection is incorrect too.
    May 2009
    New Jersey
    There is a grounding clamp and wire on the black gas piping where the piping exists the interior foundation wall. I don't know why an additional clamp was installed on the csst piping itself. The joint in the ground wire is soldered.
    Richard,
    While it's good that it was "also" properly bonded, but still not good that there is a clamp on the CSST itself. That should be removed.
