    Feb 2018
    Illinois
    Default sump pump discharge
    You guys were so quick and good with the first question I might as well try again.
    A sump pump discharge pipe comes up out of the well,(pit), in the basement, goes up about 2 feet, over 2 feet and then back down into the concrete. From there I am guessing, but it looks like it goes over into the grinder, (injector), pump.
    Is this a new typical way of routing the discharge of the sump? no more outside? Is it typical allowed to be pumped into the waste water system of the city?
    I typically inspect a lot of older homes but I've inspected 2 new homes in the last week, and they both had a sump pump set up like this.
    Thanks for the help again
    Rick
    Capistrano Beach, CA
    Default
    Hello Rick Beeman,
    I'm Brian Hannigan and I am the creator of InspectionNews
    Welcome aboard. Enjoy your visit here at InspectionNews and if there is anything I can help you with just let me know.
    InspectionNews has many Member Benefits available to you. Some save you time, others save you money and some do both!
    Make sure you view the list of Member Benefits at: http://www.InspectionNews.net/home_i...MemberBenefits
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Default Re: sump pump discharge
    Quote Originally Posted by Rick Beeman View Post
    Rick
    Rick,
    That is not something that I have seen; however, in San Francisco, street runoff is routed into the sewer system instead of a separate drainage culvert. I think the best bet would be to contact the city in which this was installed and ask them.
    The vast majority of sump pump systems in my area discharge to the exterior. The few that I have seen that discharge into a sewer/drain were done incorrectly.
    Rick
    It is best for all and for future reference and searches, to post questions in the applicable forum (see the main list).
    Jun 2018
    British Columbia
    Rick,
    I agree, because we won't know unless we contact them and ask. In my area, the systems discharge to the exterior as well.
