    Erwin, TN
    Default Electrical panel location
    Does this mean the electrical panel is supposed to be located inside ? Please don't call me a dummy.
    Default Re: Electrical panel location
    I would say yes, that is a flush mount interior panel.
    That panel is not for use outside. It does not have a 3R rating. It also looks too high.
    Is the label on the cover, on on the panel enclosure itself? I see the photo showing a label on the inside of the cover door, but is that the label in the photo?
    If on the cover, maybe the panel enclosure itself may ... may ... may be suitable for use outdoors with the appropriate cover.
    Of course, if that label is on the cover ... the panel may be some other brand and that label may not even be applicable to what is behind the cover. Maybe there is another label on the enclosure behind the cover?
    Just raising some possibilities.
    You got that switch and receptacle, presumably.
    Erwin, TN
    The label pictured is on the inside (on the panel door)
    Sam,
    I suspect you already figured out that the label tells enough of the story to make a recommendation.
    Jun 2008
    So what is the max height for a breaker or disconnect? Is it 6'7"?
    Mar 2009
    Colorado Front Range
    6'7" to the center of the grip of the operating handle.
    So this panel is too high??
