Thread: Panel location
    Erwin, TN
    Default Panel location
    Would this basement electrical panel install be considered a wet or damp location since its mounted on a block wall that is not underground were its installed ? Panel does not have plywood behind it to create that 1/4 air gap- space from the wall that's stated in the IRC 2012 code book (this county is going by the 2012 code) ??
    Default Re: Panel location
    Sam,
    Most surface-mounted panel enclosures that I have seen have little dimples that hold the rear wall of the enclosure away from the wall. It kind of looks like there is a small space between the panel and the block, but I can't tell for sure.
    If the wall does not get wet, then it seems to me this is not a wet location.
    The required space is built into the panel back.
    See the NEC for the definition of location, wet and location, damp.
    MONTREAL QUEBEC-CANADA
    Can the CMU wall become damp or wet.
    Typically, I see boxes/enclosures mounted on plywood substrate secured to CMU.
    312.2(A) requires the gap, at least 6mm/1/4" inch, if it is in a damp/wet location.
    This a crawlspace?
    Cables are not installed correctly. Article 334.30 states: secured within 12" inches of the box/enclosure, equipped with cable clamps.
    Exceptions. 314:17(c) nonmetallic boxes, to which the image is not.
    A better photo (higher resolution and better focus) would help.
    I think I see the standoff mounting dimples which space the back of the enclosure 1/4" out from the surface of the wall ...
    ... and I think I see greenish/blueish concrete fasteners installed NOT IN THOSE LOCATIONS ...
    ... which pulls the back of the enclosure tight to the wall.
    Mar 2017
    California
    Off question, but I agree with Robert: Quote
    {Cables are not installed correctly. Article 334.30 states: secured within 12" inches of the box/enclosure, equipped with cable clamps.}
    Surprising (not really) that two HIs called out, and gave a code reference for, not properly secured, but neither called out the not maintaining spacing (actually full blown bundling).
