    Ft. Myers, FL
    Default Gas line in fireplace
    In a fireplace that used to have a gas insert, but now does not, is it OK to have the old gas line capped off in the fireplace. There is a shut off valve.
    Paul Kondzich
    Ft. Myers, FL.
    Default Re: Gas line in fireplace
    Quote Originally Posted by Paul Kondzich View Post
    I don't see a problem with it. BUT.............!
    My concern would be with the condition of the innards of the fireplace. What is the condition of the FP, damper, throat, smoke shelf, the flue (tiles) pipe, etc. Inserts can cause a great deal of damage to a masonry FP. At a minimum I would call for NFPA 211 14.3 Level II Inspection.
    Oct 2007
    Wichita, KS
    This should trigger a Level 2 Chimney Inspection. The fuel and the appliance has changed.
    Sincerely,
    A. Bart Ogden, President
    Home Safe Hearth & Chimney, Inc.
    Wichita, KS
    Voice 316-265-9828
    Fax 316-265-9890
    www.HomeSafeKS.com
    Kalamazoo, MI
    No problem with the capped pipe (unless it's leaking). This is how it is done around here. Thus, if the new owners want to convert to gas logs (you can tell them that a gas line is present).
    RJDalga
    http://homeanalysts.com
    Kalamazoo, MI
