    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Draft hoods , combustible material
    Default Re: Draft hoods , combustible material
    Would you consider PVC (used for water supply) combustible material?
    PVC is not allowed for use as water supply/water distribution piping.
    See the other tread and the code references given there.
    If it's cpvc, I believe it should be at least 18 inches from the hot/cold connections at the WH.
    Draft hoods need 6 inches clearance from combustible material correct?
    I believe so, yes.
    Cool Re: Draft hoods , combustible material
    It is 6 inches, just like single walled vent connector. Even if B-vent is sitting on top of the draft hood, the clearance is from the hood itself. I find melted pipe insulation all the time.
    Jeff, the definition for non-combustible is ASTM E-136 or essentially Superman's cape. Do you think PVC can withstand a 1,382F vertical tube furnace without bursting into flames, crumbling apart or losing 50% weight? FYI, even Wonderboard cannot pass this test.
    Tim Moreira's Avatar
    Tim Moreira Guest
    So that's why your not supposed to "pull on Superman's Cape..."
    So the song goes
    1,382 degrees F, guess that is 750 degrees C?
    I like your "Superman's cape" explanation of that test. I may steal it for use now and then.
