    Default Plumbing Fixtures with Lighting
    Has anyone ran across these fixtures that actually have a colored lighting LED system that changes the appearance of your water? You can change the color depending on your mood or preference.
    Not going to see them in the Big Box stores for a while as they are a European product at this time so they are really expensive.
    rick
    Default Re: Plumbing Fixtures with Lighting
    I have not seen those, but have heard of ones which change colors based on the temperature of the water.
    Düde - That's awesome.
    imported_John Smith's Avatar
    imported_John Smith Guest
    Im impressed. A home inspection at Austin Powers pad.
    Shagadelic
    Yeah Baby!
    Rick,
    Was there one of those blue things making blue water in the toilet bowl. It maybe siphoning into the shower.
    Shagadelic
    Yeah Baby!
    I can just hear him yelling "Who does Number Two work for?!"
    Joshua Hardesty's Avatar
    Joshua Hardesty Guest
    Are those Hansa? If so they are pretty pricey. (But some of them look reaaally nice.)
    Also, for the cheaper swinger, you can go to thinkgeek.com and buy some screw-in aerators that have the same effect.
    Josh,
    Yep, those are Hansa fixtures.
    No comparison to the screw on type though.
    rick
