    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default shingle to peel n stick
    any problems with this detal?
    Default Re: shingle to peel n stick
    Without having more information, I can only be general.
    Yes, in that situation, that is one method of doing it.
    But there are problems with the way it was done.
    IMO the gutter discharge is clearly a problem. The shingles location on the modified bitumen membrane is almost certainly a problem, but the various roofs' slopes' apparent direction and pitch could be misleading in that picture.
    That's a very common (and poor) design around these parts, with many roof planes terminating at a small, low-sloped section. Difficult to cover, but more difficult for an inspector to see the details below the backwards-overlapping amd uncovered shingles.
    That would be my absolute last choice of material for the flat part... as others said, it's tough to see the whole install once it's done and from the picture.
    Jerome,
    The flat section does not appear to be peel and stick to me. I would guess modified bitumen (as Michael said) or a cap sheet.
    As others have said that install is all wrong.
    Don't forget that with a shingle the water needs to flow over and across the shingle from top to bottom. If the water is flowing from the side and across this can force water under the shingle and you will have leaks.
    With a flat area like that I would like to see an EPDM type roof. I would like to see the valley more defined. That is just a poor design for a roof.
