Thread: why the corrosion?
04-03-2019, 06:36 AM #1
why the corrosion?
My search for a main water supply cutoff found this device (pressure regulator) with a corroded connection to copper supply line. Why is it corroded and leaking?
04-03-2019, 06:55 AM #2
Re: why the corrosion?
Galvanic reaction..........dis-similar metals.
04-03-2019, 07:20 AM #3
04-03-2019, 07:34 AM #4
Arizona Home Inspections & Consulting
WWW.arizonahic.com
Expertise to protect you and your investment. ®
04-03-2019, 07:40 AM #5
04-03-2019, 07:55 AM #6
Looks like copper to a galvanized steel nipple to a pressure regulator and back to copper.
As previously stated - galvanic reaction (rusting through) due to dissimilar metals.
04-10-2019, 02:01 AM #7
04-10-2019, 06:26 AM #8
Thanks for the replies.
1975 ranch on crawl. Because it is an active leak I called for a plumber to go under there and fix the leak, and install a main cutoff on the riser.
04-10-2019, 06:30 AM #9
Always interesting to see photos from other inspections.
No floor insulation or sill plate under the floor framing?
Keith
04-10-2019, 06:49 AM #10
