Thread: Structural Engineering Question
01-25-2008, 04:49 PM #1
01-26-2008, 10:09 AM #2
Re: Structural Engineering Question
How do you know there are no lintels?,
What are appropriate deflection tolerances?
Do you own a camera?
01-26-2008, 04:38 PM #3
Based on the limited information, neither are structural in nature. Consider a problem with the mortar mix, or conditions during application.
Randall Aldering GHI BAOM MSM
Housesmithe Inspection
www.housesmithe.com
01-26-2008, 07:10 PM #4
I can show him a building several blocks from my office where oxide jacking at the lintels is lifting the entire second and third stories of a half-block long Chicago structural masonry 1920's apartment building converted to condos up and out - it's costing the association around a three quarters of a million dollars to stabilize and repair. Extreme case admittedly, but the only obvious indication at the exterior was "cracks above the lintels of square windows"....
01-26-2008, 08:52 PM #5
01-26-2008, 09:40 PM #6
Wendell,
I think that the PE veered off course when he made a blanket statement that cracks over square openings are not a problem.
I looked at a 1 yr old 2 story last month. Brick veneer corner of second floor centered over O.H. door. Top of door opening is sagging, cracks from door up to roof. Homeowner is taking the builder to court. Prior to building this home the builder was banned from construction in the village (Glenview) for one year due to lousy workmanship.
It seems that a header wasn't part of the framing game plan. They also skipped squash blocks - virtually the entire basement ceiling was just re-drywalled. This due to a slight plumbing problem on the second floor from poor installation.
Apparently the builder didn't forget his tricks of the trade - or learn any new ones - while he was on leave.
01-29-2008, 03:04 PM #7
Wendell;
Perhaps the P.E. was pulling your leg. Making generalizations such as the ones he made are inappropriate. That is why site visits are necessary to determine what is happening. Answer the P.E.'s question with another:
Would a P.E. make such a determination without additional information collected from a site visit, and possibly looking at blueprints of the original construction, if they are still available?
www.housesmithe.com
01-30-2008, 10:55 AM #8
