    Jan 2020
    Michigan
    Default Wet Outside Walls
    Hi! Guys,
    Can you tell why the wall is wet here above and under the Window? Please see attached Pic.
    Capistrano Beach, CA
    Default
    Welcome to InspectionNews!
    Thank you for registering and posting your message here.
    If there is anything I can help you with please let me know.
    InspectionNews has many Member Benefits available to you. Some save you time, others save you money and some do both!
    Make sure you view the list of Member Benefits at: http://www.InspectionNews.net/home_i...MemberBenefits
    Sincerely,
    Brian Hannigan
    Twitter: @InspectionNews
    Aug 2011
    Default Re: Wet Outside Walls
    There are several possibilities.
    Water draining from the roof down inside the wall and finally showing on the brick.
    A leaking pipe or fixture at the 2nd story.
    Some problem with flashings on the wall.
    And could be something unusual.
    But it looks like something that you should have evaluated more sooner than later.
    Quote Originally Posted by Ranjan Sen View Post
    Hi! Guys,
    Waaaay too little information to go on. We don't know what is going on in the interior. We don't know what is going on above. A picture may be worth a thousand words, but even that can be inadequate.
    I'll take a shot at it!
    How about missing sprinkler head under window.
Tags for this Thread
